Smoking
satusai
My 1990 964 emits slight amount of bluish smoke only when engine is idling. Leakdown test only advised exhaust valves need reseating so should I be concerned?
Car has done 85k and been regularly serviced.
I'll pitch in with a starter... When the exhaust valve fails to seat correctly it does get hotter as it doesn't conduct heat to the head as effectively. I assume this additional heat causes the oil seals around the valve to go plastic and when this happens oil gets past. When you get the valves done, whether in the short or long term, this can be rectified fairly simply.
Thanks. Not sure of make but I know it's SAE 10w-40 which I believe it the recommended.
