So it leaked!
lali
Ok... The rear footwell was well sodden from unknown days of rain. I am pretty sure the culprit is the sunroof and will be ordering a new seal on tuesday, until then the junk in the garage has been arranged on top of the car ina Bukaroo styly!
When I was inspecting under the carpet I noticed that the "bakalite-esq" material that sists in the floor pan had cracked and was holding a lot of water under it so in true "thei is NOT how I wanted to spend a hungover Jan1st" I ripped it all up in an attempt to get to all of the water. I then "surgically" removed the part of the carpet that sits in the footwell.
So my question is what was the bakalight stuff and can it be replaced or do I just attack the exposed floor with some hammerrite and put the carpet back down when its dry?
also how have other people dried out their cars??
ORIGINAL: lali
Sticking it in the garage was a good first step, has never happened in a 944 to me but has in a previous car. Seats out, carpet up and a 2kW heater/blower aimed in the footwell with all windows/hatch open, it took 2 days to get it dry. I never sourced the leak and sold the car 2 weeks later (but i am not suggesting you do the later) [:D]
You're unlikely to get a sunroof leak in your car slim :rolleyes:
lali - not much help but......in anticpation of future problems......
1. How much is a new sunroof seal?
2. Is this "the usual suspect" if you get a leak?
from what i can gather there a couple of usual suspects...
1. Bloackage of one or ore of the 4 drain holes in the sunroof channel... clean them out with a legth of curtain wire or similar
2. Sunroof seal
3. Rear quaterlight seal
4. Rear hatch trim seal
5. if the trim around the sunroof ( inside ) is loose then it can be a cause as well.
Dont know how much a seal is yet but I'll ring around and post what I find here. It cant be as much as the grief the leak has caosed me! and it cant hurt to change it.
