DavidL
I need a little help if you would. Further to my previous posts I have now refitted my recon'd starter motor and found, no change - still just a click when I turn the key. I was told that the armature was worn out hence the recon but now I'm wondering. I tested the sm as per Clarks garage in situ and it didn't seem to work.
Follow my theory if you would:
Ignition switch - if the immobiliser is armed then all the dash lights but turning the switch gives no reaction, as it should. However arming the immobilser gives said click so I figured the switch is doing something.
Starter again - well if I had not connected the wires properly or at all I would get a different symptom but I am getting the same as I have had all along so not that?
So now I am wondering about relays - it is sort of a relay type click, if a little loud. So DME? Is there a starter relay?
Some days it is a good challenge others it drives me mad. I'm convinced that if I concede and get a little man to come and sort it it will take him about 10 minutes and be really obvious but I am going to resort to that soon as I am fed up having a levitating 944 filling the garage. At least I've got other transport.
Anyway any thoughts gratefully received.
David
Edited - is this starter likely to be the same as found on a late model (90) 944T?
David
