solid subframe mounts - pros/cons
- Thread starter silver7
HTH
cheers
John
paul howells
paul howells
They were not worn at all.They dont get a lot of movement/wear
My 993gt2 that i had was a rhd road car,which was fitted with solid mounts from new.
FVD supply the kits
Richard Dawson
I think uprating anything causes a circle of issues.
I took the view that in relation to the road use I do I tend to keep out of potholes and rarely ever give it grief on the road. The rest is driving to trackdays/Ring which is often motorway.
When on track I always try to keep off kerbs to save giving any of the suspension too much grief; I am not there to put in times.
Again I think they were in GT2 evos which were road cars so I imagine Porsche scoped out this issue?
paul howells
Its also a fairly big job,and complete reset of geo etc,i would also recommend doing the front lower bushes as well,but not solid or rose joints for the road.
If you dont drive the car that hard,the car is very good standard,also lowering the car stiffens things up a fair bit.
When i done my car ,it was certainly tighter and more responsive,especially to throttle steering,it felt like a 964!
Also make sure your lsd is in good order,its a slippery slope once your on it!!!
silver7
to far less stress levels, will digest what Paul has mentioned, MOT due and will have a good visual on the ramps.
