Some advice/guidance on wiring in my wideband gauge kit please
Dan944t
hi guys,
Can anyone help me with some advice on where to take the wires from, to get my AEM wideband gauge up and riunning.
im thinking all I need is to power it up and get the illumination on for night time , but that may be possible with just power supply?
I womy be needing to hook up any of the linked communication wires yet as I don’t have another AEM gauge yet and also won’t need the data logging one yet as I am still running standard type ECU not piggy back. I’m thinking an in-line low amp fuse will be a good idea.
just need help knowing which wire to tap into and where ms the best place from? To get it up and running.
thanks all
Daniel ??
I took a power feed from the cigarette lighter. Much, much later I wondered why my Sat Nav battery went flat.
I’m wondering if taking it from the clock would be a good idea?
Blade do you remember how many wires yours took to power it up and running?
Hi Dan
I just asked my son of he could tell me how he connected mine, mines wired directly into the ECU as he wanted a partial closed loop, think it works on idle and partial throttle only. He said all you really need is an ignition connection and earth, I got the impression it's pretty straight forward, I'd have expected there to be a wiring diagram in your kit? If not perhaps try google for your make kit.
Pete
Sorry no, it was a long time ago. And mine is an Innovate kit.
PSH said:
Hi Dan
Pete
[:(] So you don't know the AFR when you're on boost/flat out?
PSH said:
Hi Dan
Pete
Cheers pete,
yes im gonna hopefully have a bit of time Sunday to look into it, i was just wondering If anyone who had done it knew where they took the power from so I had a better clue, just incase I take it from the wrong place.
cheers blade ,
im thinking the clock might still be a good idea? I’ll look into it on weekend better when I’ve got a little bit of time to investigate.
Daniel
Hi Dan
I have my boost and AFR gauges in a carbon fibre plate below the stereo. I also have an AEM wideband. I piggy backed the power for both units from the stereo permanent live. It's worked faultlessly for years.
Stuart
scam75 said:
Hi Dan
Stuart
Never thought of that!
cheers Stuart that sounds like a better and easier source to work on??
