Sandspider
The good news is, I've finally traced my odd oil leak. The bad news is, it's coming from the crankcase where it joins the block
. Only noticed as it's in the garage to have the fuel tank cover put back in place, and it went up on the lift while the engine was still hot. (It's not a huge leak, and doesn't happen when the engine isn't running- it doesn't drip on my drive for example)
I understand that to replace the crankcase seal, the gearbox and some of the transmission need to come out? (Indie said it was best done when replacing the gearbox, but the gearbox was replaced shortly before I bought the car!) Bugger. There's a few other niggles with the car (handbrake cable stretched, steering wheel bearings not great) but the oil leak is more of a pain. (It's been getting through a litre or so every few hundred miles). Now, I don't want to get rid of the car, but I can't really afford the labour required to get the gearbox and all out to replace the crankcase seal. Is there anything I can do in the meantime to reduce oil loss? And presumably, as long as I keep the oil level topped up, the car's not going to suffer damage due to a leak in the crankcase?
If I do have to have the crankcase seal replaced, is there anything else I should check / replace while there is access to the hard to reach places?
Cheers...
Giles
Cheers...
Giles
