DavidL
Rear heated screen won't work.
I had to change the drivers side strut as it was leaking. Prior to that the alarm, rhs and boot light didn't work. Fair enough, I've had this before and you need the struts working properly for these electrics to function.
Replaced the drivers strut and the alarm and light works fine but not the screen. The strut came from a reputable indie, is handed etc so should get everything to work.
I bought a pair of struts so I tried both new ones, same result.
So a very amateur electrical diagnosis gave the following but didn't really help me.
Disconnect the wires to the struts at the back seat (so lower) end and there is a constant 12v supply between the 2 with the hatch open or shut. But if the struts are reconnected and I measure from the same point 0v. How does that make a difference?
Measure from the hatch end of the struts and 0v open or shut, rhs switch on or off.
Only thing I can find is that of the 2 different passenger side struts one has a circuit between the 2 electrical tabs when open (uncompressed) and off the car and the other doesn't. On the car they make no difference.
I'm assuming that with the hatch shut and the rhs switched off there should be no measurable voltage between the 2 tabs, hatch end and the struts in place(by the wiper motor box) but flick the dash switch and 12v should show.
I can't find anything obvious and its annoying me.
Any ideas?
Any ideas?
