peanut
In an effort to cut down on noises emanating from my engine, I have been turning up the radio but lately its just not cutting the mustard so I'm looking for an alternative to neutralize the ticking injectors, valve shims and squealing alternator bearing that turns heads and announces my arrival from 1/4 mile away.
Did the 944S2 ever have any sound deadening material fitted to the underside of the bonnet at the factory ? Mine has never had any so I assumed it never did.
If I were to fit some what type of foam and thickness would you recommend ? I was looking at some polyethelene closed cell foam about 5-6 mm thick ...what think you ?
