Sound deadening
Pretty sure he means the sound pad in the engine bay at the top (that hangs down on a lot of cars)......
I've removed mine due to its bad condition. I was going to replace it but without it not too much of a difference is audible.
My foam pad has the common sagging[:mad:]!
Is there anything else - maybe something more durable ( potentially not quite as good for acoustics ) that you can fit.
Is it feasible to fit this with the engine in situ? - presume you need very long, very thin arms[8|]??
Hi. No its very easy, even with guns like John Wayne!....
Yes there is a very good item from FVD for a price that is actually better than replacing with stock. See link below.
Its a fiddly job made easier by removing the ICV and airbox. If your car is a varioram it may be harder. Overkill for sure but you could remove the engine mounts and drop it by a few inches to improve access. Easily done but not really necessary for this job.
http://www.fvd.de/de/en/Porsche-0/-/-/-/item/item_details/VID_73879192-VCD_51207279-gid_0-sort_4-display_50-item_99355628100/99355628100_Sound_absorber_mat.html
-phoenix
