source for gear shift lever bush ?
- Thread starter peanut
peanut
cheers I thought they would be about £50 from OPC . The postage on small stuff is usually the killer.ORIGINAL: Eldavo
Mcnulty mode on: it's only a few quid from an OPC.
Stick it in some hot water before fitting it to make it easier.
I'll ring Exeter in the morning
pauljmcnulty
Mcnulty mode on
Peanut, try Glenn at PC Leicester: he will be more likely to post it out at a better rate. Just not had as much good feedback from Exeter for a while now, which is a shame.
peanut
thanks thats a nice surprise.ORIGINAL: Waylander
If it's the bush at the bottom less than £3 from OPC
How are you doing Martin ? we are all wishing you a speedy recovery buddy
peanut
ORIGINAL: pauljmcnulty
Mcnulty mode on
thanks for the tip Paul. I've not ordered from Exeter for 2 years or so but they used to be pretty helpful Maybe the guy I remember has left the parts dept.
I'll contact Leicester as you suggest thanks
Waylander
ORIGINAL: peanut
Yes not too bad all things considered, at home now resting and trying to get my head around what happened.
Not even seen my car for two weeks and can't drive for another week, but got a month off work now.
Thanks for asking
peanut
Also ordered some plastic carpet studs for the hatch carpet at £3 each ! and some metal carpet studs for £4 each (3x seperate pieces)
Not in stock but they'll ring me later in the week when they get them in.
Young Adam couldn't have been more helpful and even sent me a couple of emails with parts illustrations .
MarkK
Adam is Glenns sidekick very helpful young bloke.
