hello chaps
it's probably been covered before but whenever I try a search through threads it never finds anything. anyhow
I'm in the process of fitting new rims to my 85 944 lux. I know that I need additional spacers so that the outside rim of wheel sits where the current wheels do.
on the rear hub there are some very long studs with a 20mm spacer slid over top.
on the front it looks like below picture.
The spacer dimension I require on top of what I have at moment is 15mm so
Do I just need to remove the alloy front bearing hub so that longer studs can fit in and allow a 15mm spacer plate to slip over for the front? and do I fit even longer studs to the rear so that the 20mm spacer can be added to with a 15mm one?
I ask this as I'm unsure if a spacer plate comes with wheel studs fitted and you simply use the current wheel studs to lock the spacer plate in place. any help is much appreciated.
