Hi
I've had my a/c serviced and an MOT recently (by different garages).
It would appear some kind mechanic misplaced the jacking pad and pushed on the pipes running along the RHS of the u/body.
As it was on the rear corner of the under tray no damage is evident but a small leak puddle was held in the tray and dripped on the garage floor.
The two pipes in question seem to have a microscopic leak from one of the aluminium blocks which join the pipes to their rear sections.
As it's a greenish fluid I take it that they are coolant pipes with O ring seals in the joining blocks.
As there appears to be no damage do you think it's a drain down and fit new O rings job?
Your comments would be appreciated.
Second item. I have a new 996 Turbo Air Cleaner Element which won't fit my car. Is it of any use to someone?
Gerry
Gerry
