spark plug coils
- Thread starter devans
thirteeneast
Easier said than done m8. Need to drop the muflers to get to those bad boys. From under car drop Mufflers, remove cylinder head heat sheilds, and then under there are your coils. 2 bolts on each.ORIGINAL: w852dh1 I had a look at mine when it was up on the ramps for a service and noticed 2 on the way out and 2 not so good, so when I dropped a cylinder, I replaced all 6 - something like £35-£40 a piece (which I thought was reasonable). My Indy did it on axle stands, but with the rear wheels removed (so much work on, her lifts were both busy!). I reckon it took about 30 mins to do all 6, so the labour was minuscule - I'm sure the fact she gets the parts cheaper than I can more than offset the labour cost - plus I had a cuppa whilst she did it!!! Only downside was I noticed how wrecked my rears were whilst they were off and ended up buying new rears (which cost way more!!!! [])
watlina
garyw
Moderator
And thus reflected in the OPC labour costs []ORIGINAL: steveoz32 I heard you really need to remove the rear bumper and IC's to get to them on the turbo, sounds a lot more 'fun' than the NA
