After purchasings 6 new plugs and coil packs, I started to tackle the job for the first time,the first plug came out quite easily, but when I compared the new with the old there was a about a 3 m/m difference in length in the new plug,I dred to think what would have happened if I had fitted all 6 plugs and then turned the key, I checked with euro part and the part numbers checked with the car registration.needless to say I fitted 6 plugs of the smaller size,so be advised ,don't rely on part numbers ,and always check the old with the new
Spark plugs
- Thread starter porky700
pjwakefield
~Even stop and think that maybe the old plugs were at the wrong length, did you check your manual to look at what they were meant to be set at?
