Speaker rumble
- Thread starter martynbox
Black80XSA
For the first, try ebay - normally sell for £30 a pair, but since they are so poor quality the price from the OPC with the PCGB discount might be OK.
If you want to tackle it (easy really) then email me and I'll run you through it.
Black80XSA
The 1" tweeter will fit inside the standard factory grille, but you'll have to file off the lugs on the back (the factory tweeter position is 0.75") and hot melt glue the tweeter to the back of the grille. Not a big job.
However given that the tweeter sits next to the woofer, and is firing up at the windscreen glass, it can't give any better sound staging than a straight coaxial unit.
Heres a link to the MB Quart units - retail about £40 i think - mounting depth 43.5mm
http://www.mbquart.com/en/produkte/car/discus/produkt.php?nr=dkg_110
Whatever you fit you need to be wary of the total depth of the speaker - there is a aluminium bar running under one of the grille positions which will foul on the speaker if its too deep. Heres a link to the MB Qaurt units - retail about £40 i think - mounting depth 43.5mm
There are plenty of 4" coaxials on www.bassjunkies.com - Kenwood / Pioneer for £15 ish !!. Just check the mount depth first !
