Speed Limit/PDLS+ camera water ingress - 718 platform
Tony_Br
Driving my Spyder last week, after several days of heavy rain, I had the MF display announce that speed limit display and high beam assistant functions were disabled.
On taking a cursory look from outside, it was clear that there appeared to be a build-up of condensation on the inside of the screen where the relevant camera is sited.
Has anyone else had this problem?
If so, was it caused by moisture in the atmosphere (i.e. genuine condensation), or a water leak running down the inside of the screen, from the header rail?
TIA
Yep. I’ve had it. It clears after a few minutes. It’s just the glass misting up. I wouldn’t worry about it.
Dan.
I had the same in my 992, just put the front screen heater blower on max for 5 minutes and it clears the fault.
