Speedline wheels re-furb?
- Thread starter roygarth
cost;
4 x £45 to have the centres and bells refinished in correct colour powder coat
160 x bolts zinc plated = £40
Tube of exterior silicon sealant = £5
Nitromors equivalent to remove lacquer from rim = £6
Loctite for threads = £3
10mm socket = £3
Quite pleased with the results.
They are now immaculate and under cover in a spare bedroom!
(note P-Zero logo is adjacent to valve, tyre fitter thought I was nuts?)
![speedlinetyres1.jpg](http://i897.photobucket.com/albums/ac178/webupload1983/speedlinetyres1.jpg)
It was really overcast that day, but the shine from the Speedlines gives the impression it was actually quite sunny! [
I actually found it quite interesting, the procedure is hardly complicated.
How long did it take you to post 5918 times on this forum?
Just adding a bit of colour to a Speedline wheel refurb thread, please feel free to delete my post and picture if it is not suitable PCGB content,
Cheers.
Konstantin
may I ask what did you do the the outer rims? did you polish them and revarnish
did you had any dents ?
Konstantin
I had considered having the rim anodised, but the finish is less shiny than standard.
My rims will be rarely used and regularly polished after use, I am not a fan of actually using Speedlines as they are heavy, but they do look good!
I believe you can buy outer rims from;
www.fvd.de
There are also polished stainless outer rims available, but these appear to have a different edge which looks non standard immediately.
ORIGINAL: clubsport
I am not a fan of the lacquer. so I removed the old lacquer with paint stripper and just polished up the rims with solvol autosol.
www.fvd.de
Bloody polisher!
Konstantin
thanks for your reply, I polish enough rims with 3 classic motorcycles with Boranis,
well, when it comes to polish those rims; in between the bolts ... we may hear you swearing ...
as you said it will not happen that often..
Konstantin
![IMG_1682.jpg](http://i169.photobucket.com/albums/u236/rivieram002/IMG_1682.jpg)
Stainless Steel rims, low maintenance, much higher quality than aluminium, same weight and visually far superior imho,
if you do the alloy rims as clubbie says do not lacqeur just need to keep on top with metal polish, ( Brilliant metal polish is the best )
as its liquid and much easier to use than solvo autosol toothpaste [
still a heavy wheel in comparison the bbs though.
Steve, no questions to be asked about the rims, more about the non standard dimpled heads of the bolts fitted.
Is this a subtle twist on originality that allows you to enter the "modified" section at a concours event? [
the speedline bolts work out quite expensive to renew, the non original bolts were 0.90 euro each from Germany.
I also had the centres painted in VW reflex silver rather than the speedline silver, the reason, reflex is a brighter silver which Adrian kindly obliged cos the customer is always right [
Konstantin
Steve, they are really nice ....
I live in France so sending the wheels in UK is very expensive, I will have to get them refurbish here,
would you know where I could possibly get the stainless stell rims and Speedline stickers
Konstantin
the invoice description details are OUTER RIMS IN STAINLESS 18 x 1.75 CD, 374.2 PCD 391, 1 holes 40 Polished, you could also ask to duplicate my original customer order PK - 2009 dated 15/12/2009, if you can supply a French Company Vat number then there is no German VAT to pay,
they can supply the M7 x 35mm Bolts also, The 'SPEEDLINE FOR PORSCHE' are not transfers but are actually etched into the rim using templates & media blasting or acid, Adrian Rowlands ( 07831 572087 ) does this here in the UK, it may be worth speaking to him as I know he also did the
transfers in the early days before he perfected the etching method he currently uses, he may be able to post you out some speedline for porsche stickers as an alternative to etching.
The cost of the 18 x 1.75 stainless rims was 146.30 Euro per rim in 2009 so I would expect a price rise, you also have the option of having a wider dish on the rim if required, if you are running 285 tyres then it may be worth going wider by .25, you may need the arches rolling inside
to give you extra clearance, hope this helps, good luck.
Salut Konstantin, l'inox jantes sont fabriqués à la commande d'une entreprise en Allemagne à savoir Pertsch & PARTNER, il n'y site est www.titanium-touch.com, le numéro de téléphone est +49 6150 7026, il ya une dame anglophone appelé Michaella qui vous doit demander,
Description des détails de facture sont bord extérieur en INOX 18 x 1,75 CD, 374,2 PCD 391, 1 40 trous poli, vous pouvez aussi demander à dupliquer ma PK originale pour la clientèle - 2009 15/12/2009 daté, si vous pouvez fournir une société française numéro de TVA alors il n'ya pas de TVA allemande à payer,
ils peuvent fournir la M7 x 35mm Boulons aussi, le «SPEEDLINE POUR PORSCHE» ne sont pas des transferts, mais sont réellement gravé dans la jante en utilisant des modèles et des médias de sablage ou de l'acide, Adrian Rowlands (07 831 572 087) ne présente ici au Royaume Uni, il peut être vaut lui parler comme je sais qu'il a également fait la
transferts dans les premiers jours, avant il a perfectionné la méthode de gravure qu'il utilise actuellement, il peut être en mesure de vous après quelques speedline des autocollants Porsche en tant qu'alternative à la gravure.
Le coût des 18 x 1,75 inox jantes était 146,30 euros par jante en 2009 donc je s'attendent à une hausse des prix, vous avez également la possibilité d'avoir une plus large plat sur la jante, si nécessaire, si vous utilisez 285 pneus alors il peut être la peine d'aller plus en 0.25, vous devrez peut-être les arches rouler à l'intérieur
pour vous donner dégagement supplémentaire, espérons que cette aide, bonne chance.
Konstantin
thanks for your reply, great info, I will contact them soon to order. I also have a UK VAT to supply,
mines are not "for Porsche" but they have some nice stickers, I actually prefer them to the "for Porsche" as they fit with just a 6mm spacers at the back, I will keep the dish in the same size as they are 8 1/2 front and 10 back, for the 964 they are as big as you can fit, tyres are 235/265 ,
thanks again,
Konstantin
PS: by the way, very good French translation ...
