davidharrow
My Speedo died gradually over the past week or so / 300 miles. It kept dropping suddenly back part way to zero and springing back quickly to the right place. Then it started dropping to zero for a few seconds (odometer stopped as well). Then longer zero periods. Then Monday morning when I pulled away, stayed on zero and 200 miles + later it, and the odometer have not moved.
Question: Is it an electronic sender, or a speedo head problem ? Is there a way to test other than putting in a new speedo and seeing if it works (after buying it I suppose !) ?
Any advise will be much appreciated.
David
David
