speedo bulb replacement
Disconnect battery
Remove horn button
Remove steering wheel
Remove 3 long cheese head screws from switches
Remove plastic ignition surround (2 screws)
pull switches over steering shaft
Remove 2 screws from above rev. counter and temp. gauge (upside down)
Pull instrument panel forward and you should be able to get at the 2 bulb holders in the speedo. If not unscrew cable from speedo and pull panel completely out.
Mind you do not trap the wires from the switches when putting them back, they can be awkward.
Mike
