My 97 C2S seems to have a vastly over reading speedo. I have put in my Garmin Sat nav which I am presuming is accurate, and it reads 33mph when the speedo says 40. At 90mph on the speedo the sat nav says 81. The car is pretty standard running 18" wheels with 225/40/18 tyres at front & 285/30/18 rears which I think were standard when the car was new. Any solutions, or are they all similar?
Speedo error?
- Thread starter stephenh
clyde
I find my speedo is slightly out when compared with the Garmin but it is a consistent 9% or so over across the whole speed range (or at least as far up as I've taken it)
Your higher figures don't seem too far wide of the mark at a bit over 10% error but the lower figures are way off. I'm not sure how you would get differing percentage errors across speed ranges as it's an electronic rather than a mechanical speedo head. Is the percentage difference linear, that is to say does it get more accurate the faster you drive? Maybe by the time you reach top speed it would be reading spot on []
My old C4 speedo was reading 10% over consistently across all speeds when compared to a portable satnav throughout the whole trip to Le Mans.
I'd say it could be the tyre circumference that's the reason.....a bit anorak, but a buddy gave me a link to a tyre/wheel comparrison site
http://www.rimsntires.com/specs.jsp
Rim size is not really relevant here, but I've compared against my standard sized 265 rears.....check the circuference and revs per mile.......
Wheels:
Wheel 1
Wheel 2
Wheel size
18x10 ET 47
18x10 ET 47
BackSpace
186 mm (7.3'')
186 mm (7.3'')
Typical Weight
~ 33 lbs / 15 kg
~ 33 lbs / 15 kg
Tires:
Tire 1
Tire 2
Tire size
265/35-18
285/30-18
Section width
265 mm (10.4'')
285 mm (11.2'')
Sidewall
93 mm (3.7'')
86 mm (3.4'')
Tire diameter
643 mm (25.3'')
629 mm (24.8'')
14 mm (2.2%) shorter.
Rim sizes
18x8 to 18x10
18x9 to 18x10.5
Circumference
2019 mm (79.5'')
1975 mm (77.8'')
Revs per mile
797.1
814.8
Rgds,
Jon
Wheels:
Wheel 1
Wheel 2
Wheel size
18x10 ET 47
18x10 ET 47
BackSpace
186 mm (7.3'')
186 mm (7.3'')
Typical Weight
~ 33 lbs / 15 kg
~ 33 lbs / 15 kg
Tires:
Tire 1
Tire 2
Tire size
265/35-18
285/30-18
Section width
265 mm (10.4'')
285 mm (11.2'')
Sidewall
93 mm (3.7'')
86 mm (3.4'')
Tire diameter
643 mm (25.3'')
629 mm (24.8'')
Rim sizes
18x8 to 18x10
18x9 to 18x10.5
Circumference
2019 mm (79.5'')
1975 mm (77.8'')
Revs per mile
797.1
814.8
Rgds,
Jon
