Morning all..
I need to confirm my speedo reading. Tyre size is fine 225/45/17 on the fronts which is nearly the same rolling radius as standard. So how many miles per hour would I be doing in top gear per 1000rpm?
I have found some information which suggests in top I should be getting 26.070MPH per 1000 rpm, meaning im doing just under 105mph at 4000rpm.. Is this correct? If so my speedo is well off.. This is all on a 1984 2.5
Hard to judge speed as the two cars mi currently driving are a new VW passat that just wafts along and an old land rover that makes everything feel like 100mph [&o]
Any confirmation would be good, I can then see about sortign it out!
