sheep911uk
My Speedo reads 10mph faster is there any way i can adjust it to read correctly?i measured it against the speed indicated on my sat nav!
ORIGINAL: Fen
The road wheel will have a diameter and hence rolling circumference of x with a brand new properly inflated tyre. Once that tyre is almost worn out the tread depth will have reduced from 8mm to 2mm or less, making a difference of some significance to the rolling circumference that is not accounted for with a change in the speedo gearing
ORIGINAL: chrisdenton
So given that sizes make such a difference, what wheel/tyre size combination will I need to convince the missus I'm doing seventy when I'm actually doing ninety. []
