Speedometer problem
BLD
I have just changed the plastic odometer on my 83 SC and reconnected the instrument. The odo now goes crazy - i mile in 50 yards and the speedo flicks straight round to 160mph while travelling at less than walking pace.
Anyone had this happen and know the solution?
Are you sure you reconnected all the wires exactly as before? I had the opposite problem. Some guys were trying to diagnose an odo problem and reconnected the wires wrongly. The speedo didn't then work at all until I got them to double check the wiring, when it returned to normal.
As Chris says check the wiring, that sounds like the solution, get a wiring diagram or search the internet for the correct wiring, I'll have a look on my computer and see if I can find what I did with mine. Be careful to get it right this time, it is possible to blow the chip if wired incorrectly and they are hard to source unless you buy thousands at a time! [;)]
Thanks for all that.
My first sentence should have read "plastic odometer wheel".
I have a Bentley manual for this car and the wiring I have used has been taken from it.
Red/Black to 12v+
Brown/Red to 31B
The third multiple connector of Double Brown/single Red/Brown to the -negative terminal. There is no connection to the A terminal as there is no cruise control.
This appears to be the correct solution but the problem persists.
Be interested to see Bones wiring solution if you can find it.
Had to do something to the interior of my SC ('81) during its winter lay-up so took out the speedo and the wiring was the same as you have listed viz:-
Red/Black to pos
Brown/Red to 31b (from sender)
Multi (Red, Brown/Red and Green) to neg
I think the symptoms you describe are more likely caused by a speedo internal problem, though high and low voltages can cause some erroneous speedo readings (perhaps with swinging speedo needle) most likely due to a failed/failing voltage regulator - I had that once. Check the voltage across the battery when the engine is running (13.5 volts or so).
I'd like to know what the resolution was.
Best wishes
That was my instinct after you said the wiring was correct - possible you may have inadvertantly done smething when you replaced the odo gear?
If you don't get a resolution, these guys may be able to help: www.speedycables.com Contact details on the site. RPM got them to refurb my speedo a couple of months ago including replacing broken odo gearing. Nice job, done without harming the seals etc. Chances are they may have seen your problem before, so maybe worth giving them a call. One thing, they don't have a reputation for being quick - RPM did a complete top and bottom rebuild plus an exhaust backdate and a few other bits on my engine in less time than the speedo refurb!
I've had experience of 'speedy' cables [:mad:] not only were they not speedy, they were expensive and rude.
dij
I have tested the voltage across the battery and the reading is 13.5. I also spoke with the Odometer Gears people in the States who said the problem would be in the electronics. So it seems a new or recon instrument is needed.
Thanks to all for your comments
