u63af
I already had a post about a year ago about this problem with my car but it has been off the road since then. Basically when the car is under full boost and full throttle it seems to hesitate and splutter, if you back off the throttle to mid way then it seems to pull better and not hesitate. I have changed air flow meter, tps is clicking when you move the butterfly. It had new plugs that were a grade colder and new leads. Anyone got any ideas?
When I first got the new leads (before problem started) they were shorting out against the water pipe. I revealec that the rubber cover that goes over the plug had moved allowing the metal to spark, I but the rubber over this again. Could it be that I have a duff set of plugs and this may be the problem?
