The spoiler warning light on my 1990 C4 intermittently stops working. By this I mean that it doesn't come on when you turn the ignition on but the spoiler is functioning normally.
Then out of the blue it will start working again, i.e. comes on with the ignition and goes out at 7 kph.
I assume it's a problem with the sender unit.
Does anyone know where this is sited. I have seen a switch within the motor/gear wheel assembly of the spoiler and have assumed it's this but activating this by hand whilst turning the ignition on/off doesn't seem to do anything.
I have cleaned up all the earthing points I can see too but without effect. I suppose it could be a fractured wire?
Hope someone can help (although I'm not too worried as the activation/deactivation of the spoiler is unaffected.)
