Does the sport button change the car to a different "map" or just the sensitivity of the throttle?
Archie
Archie
Motorhead said:And the Sport button also activates PASM if you have it.
Jeff
Andrew, I think you'll find the water temp will show 90 degrees unless the temperature is actually outside a range, so not 90 degrees when warming up or too hot - the generally accepted explanation for this is that Porsche did not want to worry people...Andrew_CS said:Albeit these indications are only `references` rather than true values given the location of the sensors.
Totally agree with this. A Policeman said it to me once, and he was serious!Motorhead said:Having said that I reckon a whacking great STOP NOW! warning light's all that's needed to grab your attention if things are getting really serious..!
