Sport switchable exhaust
- Thread starter graymay
For many, it is a very desirable option.
Paul James
I think all C4Ss have the PSE factory fitted as standard, do they not?
Paul James
ORIGINAL: oliver
IMO the PSE for the 996 is the best sports exhaust Porsche have ever done, and really transforms the quality and character of the 996. Should have been OE.
Agreed
Good for waking up the neighbours too [][][]
ashley
ORIGINAL: Paul James
Confirm not a standard item on the C4S Paul but very desirable on any 996
On my last 2 cars I've had PSE retro fitted, first by OPC and the second time by Strasse in Leeds.
The Strasse set up whilst fully switchable was installed without the cutout between 15 and 30mph and much better than the factory set up.
Mike IRL
http://www.youtube.com/watch?v=tBn73PzEics
and
http://www.youtube.com/watch?v=xVmyNZi7HWs
ORIGINAL: ashley
I agree that the cut out does spoil the sound and thats why I went onto the Renntech site that has an excellent section on how to disable this function. Takes about 30 mins to do and is quite a simple operation.
Diesel130
ORIGINAL: Peter Bull
... thats why I went onto the Renntech site that has an excellent section on how to disable this function. Takes about 30 mins to do and is quite a simple operation.
Quite a simple job, Peter ??? ... but I thought you previously said ...
I did the Renntech 'mod' as Richard suggested - and getting the cover off was not very easy, but then again I suppose its not meant to be as its sealed!!
I thought that was the hard bit BUT - as I gently lifted the diode off the board the dam thing snapped in half!!! Sod law that it would happen to me!
Normally this wouldn't matter as the diode removal means that the none cut out mode is there all the time - but I wanted to be able to switch it back to 'normal'.
As I understand it this is just a signal path from the speedo and I replaced it with a standard 1N4148 diode. I fitted a switch on the outside of the box so that I can set it back to default mode, so hopefully when I test it all will be well.
Even the simplest of jobs sometimes turn into a nightmare eh!!!
