SPORTO GEARBOX 3 TO 4 SPEED
Hi i got a 3 speed sporto and was thinking to change it to 4 how hard is this and how much will it cost
thanks
I've done this to my SC and it makes a big difference to the 'fun' aspect of driving the car. Unless you can find the parts cheap as I did then it could get very expensive.
You will need a type 925/02 gearbox and bell housing plus the early driveshafts to fit the gearbox. I paid £400.00 for a recently refurbished gearbox and £40.00 for excellent drive shafts but I struck lucky in finding a great P.C.G.B member who had changed his car to manual. If you find a gearbox you will have to establish its condition before buying or else you are looking at £1500.00 plus for a rebuild. You will also need to modify the gearshift 'gate', (fairly simple) and convert the speedo drive from mechanical to electric, you do this by fitting a transducer from VDO for about £30.00 but if you don't get the wiring correct you will blow the speedo's circuit baord and then you are knackered as finding one is like finding hen's teeth. Very few people have the knowledge to do this job so don't trust the work to Quick Fit! [;)] If you are in London have a word with Chris Turner he helped with all the major engine in/out stuff on my conversion and he is very good. Not for the faint hearted though. Also if you are near Stowmarket Berny Tester may do the work for you, he runs a sporto and is a great bloke too.
please forgive me if i have this wrong as it's now some 8 or more years since I did my sporto to manual conversion but You "should" be able to change just the driveshaft flanges saving the cost of buying a set of driveshafts i am pretty sure that's what i did anyway(I learn't this from Bert Gear, thanks Bert ) If my memory serves the 3 speed sporto had four bolts and the manual and earlier sporto had more ??? but the inner splines mating to the diff are all the same???
That's true Lawrence but in my case I was offered a pair of virtually unused drivehsafts for £40.00, no brainer really. My 4 speed sporto has four bolts.
