unclewinks
What has exactly happened,The reason I ask is because on cold start ours rattles for about 30 secs then goes quiet OPC said it was the flap in exhaust.just wondering if it is similar Paul
Hi Anthony I was told by the OPC that this item is not supplied seperatyly for the 996 - only for the 997 model. Is this an OPC available item? I just googled thepart number and came up that its from a Boxster sports exhaust. I guess they are the same? And same as the 997? Thanks again.the vacuum unit is available as a separate part 000.044.200.16 £55.03 inc VAT
AFAIK the 997 version is not the same and it fact it's more expensive at £65.45 inc VAT there is no indication that the 997 part supercedes the older part. A quick call to Cambridge OPC parts department confirms the 000.044.200.16 part is avalible in the UK at £55.03 inc VAT and of course you'll get 10% off with PCGB discount. Out of interest there is an even older vacuum unit part number for the one on the original PSE that didn't have the switch fitted but even though if fitted as new it's the one Peter's car would of had as he had it fitted latter on they will have almost certainly fitted the latter version.ORIGINAL: M030 It's the same vacuum unit for the 996, 986 and 9x7 PSE exhausts. The part nr is 997.111.680.00 (IIRC even cheaper than the 000.044 part nr).
The vacuum unit is the same for the 996, 997-1 and even 997-2 exhausts. I have these 3 exhausts sitting here next to each other, so it was easy to verify.AFAIK the 997 version is not the same and it fact it's more expensive at £65.45 inc VAT there is no indication that the 997 part supercedes the older part.
Glad to hear its now all sorted - (They- Porsch Cars must have seen this before - so why all the fuss?)[8|] Don't forget time and a half on Saturday rates for 'er indoors'[]ORIGINAL: Peter Bull On Saturday I backed the car in the garage and left the fan heater on for half an hour – no point being cold is there! I hadn't removed a rear PU before and was quiet surprised how easy it was. Less than 20 mins and with a little help from ‘er indoors it was lying next to the car on a suitable cloth.
Imagine how it feels when you need a new engine :-( Pretty disappointing really. Taking into account the main dealer servicing your car receives, when a dealer fitted part fails after 3 years and presumably a pretty modest mileage, you would hope/expect an acknowledgement that such a failure really shouldn't happen. Look on the bright side, at least you've saved £8k worth of warranty renewals!!ORIGINAL: Peter Bull As you can appreciate the whole sorry saga has left a sour taste about the standards of Porsche customer care. For the sake of a hour and a half’s labour and a £50 part the credibility of their customer care, has, for me at least, been very badly damaged.
