devans
Cant believe it. Took the car on the toll road as i havent give it a good fast run for some time. Got home to a blowing exhaust. I now has a porsche which sounds like it has a sports exhaust or even louder. Didnt cost me a penny, Ha Ha ! However, im assuming i will need to replace the silencer boxes. Im assuming you replace both sides at the same time, car has done 93k.
Can anyone forward the details, ie is this an easy job and where would you recommend to purchase new boxes (3.4 C2). Is this a job that can be done easily or is it one of those best left with a professional? Thinking of rusty nuts/studs etc
On a second point ive also found my windscreen washer bottle is not holding water. My suspicion is that the frost has probably created a crack as it gushes out the bottom of the car as quick as i fill it. Does anyone have an instruction sheet on how to remove and again, the name of a recommended supplier.
Many thanks
ps Sorry if the subject drew a lot of you to this post but couldnt resist.......HELP!!!!!
Many thanks
