sports suspension
- Thread starter SCOTJC
You have to drive it yourself to be sure how you will like it.
Ess_Three
It's appreciably lower and stiffer than the standard car...but not harsh.
You notice the front bobbing along slightly more...and it's very sensitive to changes in tyre pressures, but overall I prefer it.
Round town the standard kit is more pleasant, but get out on the open road and onto the back roads and the difference shows...more precise, less understeer, more neutral and chuckable (more oversteer too...)
The real downside appears to be if really pushing on, on really badly surfaced roads, you really have to concentrate to keep it on line...the standard cars I drove didn't appear to do this.
Overall, I'm still happy...
Retro-fitting is possible, but not cheap, and it won't add value to the car. You could use an independent specialist, but if you are considering a late car with Porsche Warranty you may need to use an OPC.
The PSE is a lot simpler and very desirable . This can be retro-fitted for c.£1,300 non-switchable, from an OPC (possibly less elsewhere) and this should add some value to the car
bladeboy
It lowers the car by 10mm which in my opinion makes the car look great but as someone else said it does stiffen the car up which means on some roads it can be a bit uncomfortable but no more I would say than the 3 series cabrio I had with sports suspension on. However as soon as you start upping the pace the suspension makes sense.
I would say try them both and see which you prefer. I drive my car everyday into London and over speed bumps and I find it fine.
Suggest you have a look on Porsches used car website as there's always some cars on there with sports suspension.
As for the sports exhaust, I looked at getting it retro fitted on mine and was quoted anything from £ 1500.00 to £ 2000.00.
As it also doesn't give you any benefits apart from more noise I went for the Fabspeed Maxflow Silencers which I've not regreted.
Great noise and its improved the throttle response. Check out the Video clips on www.fabspeed.com
Hope thats helpful.
The sports exhaust is a definite, the suspension not.
I plan to do a few track days in it so I will see what the standard suspension is like first. If I buy a 60,000 mile car are the shocks going to need reconditioning anyway??
The sports exhaust is a really personal subject. Although the PSE sounds ideal any money saved means more money I can spend on the car initially. I want an exhaust that I can comfortably live with (and so can the Mrs for that matter!) at cruising and around town speeds but one that makes the hairs on the back of my neck stand up when the right foot gets a little heavier!
