EddySpaghetti
Hi,
I read the caliper refurb thread with jealousy! - can't get my ffronts off at he moment and think they may need drilling cos I can't get heat on them in the communal garage at my flat!
Nice off topic start there...
Once i've got them off I want to fit new dampers when i stick all back together again. I've decided to go with Gaz gear, and I'd like to go coilovers at front and damper only at back, preferably adjusing rear ride height to match the new front height without reindexing. Does any one have experience of doing that using the eccentric adjuster on the trailing arm blade?
I know there isn't much movement there, so think I need to be careful on spring rates at front to give a long enough spring that also won't bind coils on compression.
I've had recommendations of 250, 300, and 'no less than 350' ! Just thought I'd ask if anyone has experience using springs at the softer end? I don't really want a racing setup as will use the car on road with occasional track days- I have thought about using soft (250) springs keeping ride height drop to about 15mm (adjustable limit on the eccentric adjuster at back?) then maybe fitting 968cs rollbars at either end to control body roll.
Would be interested in your thoughts, I'd like to go ahead and order so I can fit everyting back up in 2-3 weeks time.
Cheers!
Eddy
Cheers!
Eddy
