Springs: M030 vs M033
szklarek
I understand from the technical articles section that both M030 & M033 springs have the same ride height - lower that my standard C4 suspension. Am I right in assuming that the M033 is similar to the standard in terms of ride but that the M030, as the sports version, is firmer? If so how much firmer?
Anton
May be wrong but I think the M030 is the package on the car while the M033 is just the spring/shock kit.
I have a genuine M033 kit in stock I could do for 960.00 from Porsche 1804.56
Your basically there! The M030 sports springs and the M033 lowering springs will be lower than the M029 standard ones you have at present. I think the M033 will still be a little stiffer than M029 as it cant travel as far. How long is a piece of string though on the difference in stiffness!
My understanding is that MO33 is lower with linear spring rate, whereas MO30 is lower with variable spring rate.
Hi I used to have m030 springs on my C4 and they were too hard for street use IMHO, Mo33 is the way to go, lower than std but a good ride.
