Just thought I'd pass this on ...
I've had a very noticeable SQUEAK coming from around the passenger door for some time and couldn't figure out where it was coming from.
Initially I thought it was inside but after a while figured it was the passenger window rubbing against the actual door seal, it was worse when travelling down more bumpy roads. I assume its slight movement in the door causing the rubbing of the glass and rubber.
I had a can of 'J-SIL Silicone Spary' and worked around all the door rubbers with it, left it overnight then wiped it down and re-applied once again, followed by a further wipe down.
Guess what no-squeak ... completely gone ! []
I'm was getting a slight residue appearing on the glass where the rubber is touching it, but, after a few wipes it has stopped appearing. It simply took a little time for the rubber to fully abosorb the Silicone.
