DaveyB
Just had the car serviced and the exhaust replaced. just got to fit the lower arms and drop links when I have the time. Then everything is sorted for the summer. Well thats what I thought.javascript:void(AddText('[&:]'))javascript:void(AddText('[]'))
The one item mentioned on the service report - staining around cylinder head. Basically that means the Cylinder head gasket is leaking I assume. How big a job to take ther head off and replace the gasket?
It does't appear to loose water, and it runs fine. And there's no mayo in the header tank. A bit in the oil filler tube, but I would expect that to a certain degree.
Will the work and bills never end.
