Stalling
- Thread starter Guest
plhorner
Moderator
Check that the idle air stabilisation valve is working properly (thats the big solenoid operated one middle formost top on the inlet system), mine was sticking and gave symptoms similar to those you describe. Just disconnect it, spray WD40 into the valve port and give it a shake till you can hear / see the valve spindle move.
David.
ClubSport 911
