Stammer / missfire any Ideas!
rob944s
Around 5k rpm i get a stammer or missfire in all gears, sounds electical to me, but the car before i boght it was not used on a regular basis as it had been damaged, could it be a stickey valve? i didnt want to take the head off just to check...........
If it was a sticky valve i'm sure you'd have other more serious symptoms. The electrical system is certainly the first port of call. HT leads could be a bit old and tired now, I replaced mine recently as they were looking old and knackered and the insulation was so perished it virtually crumbled in my fingers. It ran much smoother once I replaced them. I also replaced he dizzy and rotor arm. Alot of these components don't wear according to milage or use but due to age so they are probably up for renewal by now. Obviously check your spark plug gaps. Then next to check out would be the fuel system. Good luck, I hate jobs like this!
