Hi
I bought an 87 2.5 na 944 at the end of last year. I had the belts changed and got it serviced straight away, but due to work comitments I ended up leaving the country for 4 months at short notice. It has sat in a dry garage without being started since then. It had about 1/4 tank of fuel in it.
Should I do anything special prior to starting it up? I expect the battery to be flat, but does anything else need checking? The oil and coolant were changed as part of the service.
Everything worked when I put it away (even the clock!) so I am hoping it will still be okay. At least it didnt get driven in the snow I suppose.
