starter motor
- Thread starter Guest
Fred Hindle
Don't know if the DME has anything to do with it but check your DME relay.
Someone will know on this forum, over to Computamedic.[
Cheers,
Dave Wilkinson
Basically, what Pete said. The clue must be in what noises you get when you turn the key. If nothing at all it would imply no current getting to the solenoid - typically what would happen if an immobiliser was preventing starting. If you get a "click" the solenoid is activating - that would imply no current to the motor (or a stuck motor). I think we need more detail to help.
Dave
Fred Hindle
Are there any local indies in your area? Sounds like the next step.
Cheers,
Fred Hindle
Check that the engine compartment light is going off when you shut the bonnet.
You can check if this is causing the drain by removing the bulb and then seeing what drain you have.
It may seem crazy for one light to be the problem but mine would flaten a fully charged battery in 24 hours.
Cheers,
Regards,
Neil Eldred
