Car has not been driven much, and 6 months ago developed an alarming backfire at start up - that would blow off the rubber sleeves in the engine bay!! Thought re-fitting and tightening the sleeves might ahve been a stop gap solution.
Mot time, so charged up battery and went to start car - muted back-fire and it had blown the sleeves off again.
So replaced the sleeves on the right hand bank ( had bought these last yar and not got round to doing it ) - in case these were causing an air leak.
Started up[] - after a bit longer than usual, and with a few dabs on throttle - then 10secs or so later - as I pulled out of parking bay it stalled - then I emptied the battery trying to get it started again.[]
Charged up the battery, turned ignition and again after bit longer cranking,and afew dabs of throttle it was running. THsi time I thought I'd drive roudn the block before setting off for the garage......1min later engine just died running up to a T junction[:'(][][:-] - luckily I was excatly outside the local corner shop - so I could buy a snack while waiting for Mr AA ( i'd tried restarting - but no joy ).
Mr AA tried carb cleaner in the inlet - no joy.
Checked the leads - said there was live feed going to them[], but nothing coming out []- so presumed a coil problem / hall efect problem?? ( car has 1 yr old plugs and leads, arms and caps )
Anyone any suggestions on what to look for ( booked in for servie next week ) so would be relaly useful if anyone elese has encountered this sort of problem?
Thanks, T[&:]
Thanks, T[&:]
