Starting problem when hot
- Thread starter Guest
I seem to recollect that there is an in depth description of the hot start problem and what to do about in "101 Projects for your Porsche 911"
John
Some interim solutions are keep the fuel tank full or as close as poss; the tank acts as a fridge for the fuel system and minimises vapourisation, which is what is happening on the hot start; the pump trying to cycle what has become a gas. Also reputedly helps to run your fuel pump for about 30 seconds after you knock the car off when hot, so the fuel line will fill with cooler fuel and there will be less chance of it boiling off. I have tried both solutions and the full tank thing definitely effective - up to a point. My engine cover was almost too hot to touch yesterday afternoon after a day spent parked in direct sun at Walton Hall, took three 10 second cranks to get it to fire. Not good for starter, fuel pump, engine or driver, so new accumulator ordered today []
Air flow sensor plate rest postion incorrect - inspect and adjust
Fuel Pressure incorrect - test (i assume you need the gauges etc)
Cold start valve leaking or operating continuosly - test cold start and thermo time switch
Vacuum leaks (intake manifold) - inspect intake air coponent for leaking hoses and hose connections
Control plunger in fuel distributor binding or fuel distributor faulty -check air flow sensor plate. if necessary replace fuel distributor(arggg!!!!)
Control pressure regulator faulty - check control pressure regulator full load function
Tests for each are covered in the manual. If you want I can photo copy them and post them over to you. The airflow sensor and cold start valve are really easy to check.
Rats
