My 924 Lux normally starts without problem after 2 or 3 turns of the engine. Howerver ocasionally (about 1 time in 20) it simply refuses to fire. When this happens, if jump leads are connected it starts immediately.
The problems occurs even after the car has had a good long run then then stood for most of the day - so it doesn't seem to be a low battery and definately not a 'hot start' problem. I have replaced the battery just in case.
As the problem is very intermittent it's hard to track down - any helpful suggestions welcome !
Someone suggested I replace the "ballast resistor" - can anyone explain the function of the ballast resisitor and if it's likely to be the casue of the problem ?
Jhn Cooper
Jhn Cooper
