Starting problem
- Thread starter steveoz32
I need your kind help.
We were driving only a few miles from home. We get this smell of electrical burning in the car and it just stopped. All the lights on the dash came on just as if the car had staled. But not even a click when I turned the key to the start position The AA guy did some checks across the battery and said that was OK. He said he had come across starter problems with 996's before and that had been the starter motor itself had burnt out! He then recovered us back home and I started to research what could be wrong. Reading some of the other threads on starter motor replacement I had been getting some screeching on start up. So maybe was not long for this world anyway.
On removing parts needed to get to the starter I found that the Vacuum Unit control for the resonator flap broken. From the amount of dirt on it been that way for some time. Thanks for the info on this Geoff997. This I have now replaced. The starter motor was dead so I have replaced with a reconditioned unit.
The car will still not start. I have checked the starter is working with a wire across the terminals and it turns the engine over as it should. So I am thinking maybe it's the ign switch has failed, a relay or something else stopping the power from reaching the starter solenoid.
Your help and advice would be most gratefully received.
Rgds
Steve
steveoz32
steveoz32
