(Not the usual "y" cable, earth, hot re-starting issue or low battery voltage)
Ran the car, up to normal operating temp, approx 15 miles and then stopped, parked and switched off drivers window fully down.
back to the car after a few minutes and tried to re-start.
Normal indications when putting in the key (key 1 identified and then the usual pre-start messages when the key was turned) v slow crank, almost started and then nothing i.e. usual symptoms of the failing battery/low voltage. removed the key and tried again: absolutely no response. no attempt to turn the engine, no messages at all on the instruments
Door locks work, front hood release works, engine release works, interior lights work, infotainment system works, but window won't come up
Attached a booster pack but got absolutely nothing. No clicking from the starter/solenoid no engine rotation but more concerning, no change from the instrument cluster when the key was turned to the run or to the start positions.
completely dead
if appears that some very limited circuits are powering up and the key is communicating to the car electronically, but when the key is in an rotated, nothing happening....
any suggestions?
electronic module in the key barrel?
completely dead
any suggestions?
