Inactivity kills more batteries than any other cause. Often the first cell next to the positive terminal gives up accepting a charge first (don't know why). Get a battery conditioner/charger and connect it whenever the car is going to be idle for more than a week. These devices, especially the Porsche one's come with a cigar lighter plug, which is useless for 3.2 Carrera's. The socket is dead when the ignition is off. So you will have to arrange connection directly to the battery instead.
To test, turn on headlights and try starter. If they dim down significantly get a new battery, if not the starter is more likely to be the culprit. If you can hear the solenoid clicking (quite loud) try tapping the starter with the shaft of a hammer a few times and try again. If starter then spins on next attempt it also has suffered the ills of inactivity. Get it replaced, you will not regret the outlay (about ÂŁ120) plus fitting or a few scraped knuckles. They can be a little tiresome to remove.
Good luck!
