rooksy
Hello
I'm having starting problems. The car will bump start and run okay after that. I've replaced the battery, checked the speed and reference sensors readings i am getting the correct reading between terminals 1 and 2 on both senders but dont seem to be getting any readings between 1 and 3 or 2 and 3, reading other posts this could be because the values are high and can read as an open circuit (correct me if I'm wrong). I've replaced the DME relay in the past but would like to test this part before buying yet another. Does anyone know how to test this.
Also if I were to replace the reference and speed sensor I cant seem to see where the leads run to and the Bentley guide is very vague.
Any help is most appreciated
Sean
Sean
