Hi
I have a 1985 3.2 (UK) RHD. Sometimes it starts perfectly, i drive it for 1-40 miles stop the car and when i return to start it again (it doesnt seem to matter how long after) sometimes it will not start. The key turns and hits the end of the turn and nothing! There is a resistance, as if it is trying to do something and alsoa slight hum or buz sound as the key reaches the cranking position and will not travel any further, this stops when released to the pre cranking possition but no cranking occurs. The car will start straight away with a push (ignition on and in third gear after a very short run) sometimes as i am jumping it i have tried the key and it has cranked....... as if the starter has been stuck and suddently become free?
The barrell (ignition) is a bit worn and sometimes will not turn at all but again this is very irratic and might only 'stick' 1 in 100 times.
I think it is either the ignition switch/barrell/complete unit but it might be the starter or a combination of the both?
Any advice would be much appreciated.
regards
john reynolds
regards
john reynolds
