smithne
Hi,
A slightly dumb question perhaps, but I currently own an unmodified '72 911S with MFI and would be grateful for some advice on starting procedure. No problems with cold and hot starts as the factory handbook explains what to do. However, is there a recommended technique where the engine is only slightly warm, eg after standing or 2 - 4 hours or so? I have tried various degrees of hand throttle and gas pedal and sometimes need a couple of go's until the engine fires. Just want to make sure I avoid flooding the engine, which I guess is easy to do if you don't know what you are doing.
Many thanks.
Many thanks.
