Steering boss
- Thread starter Ash944
944 man
Simply: if you buy a boss which has a fixed horn ring then theyre model specific (924 & series one 944 and oval dash/series two 944 onwards inc 968 and 964> 911). If the boss uses the horn ring from the original steering wheel then one boss fits all, but you MUST use the correct horn ring. early dash 944 et al use a 477 part number ring and oval dash 944 et al use a 928 part number prefixed ring.
944 man
The rule is: if the boss comes without its own horn ring then itll suit early or late 944s provided that you use the correct original part, but if the ring is built in then its either 924 & early dash 944 or oval dash 944 and 968.
The difference is in the horn ring which will short and possibly start a fire if you use the wrong part.
944 man
That one from the same vendor has fewer contradictions. The problem is that theyre usually 'foreign' vendors listing as many models as possible in order to attract buyers with little idea about the cars they are including.
Id be tempted to go for this one: http://www.ebay.co.uk/itm/Steering-wheel-boss-kit-fit-VW-classic-beetle-dasher-Golf-GTI-mk1-Jetta-Karmann-/400592747418?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Model%3AGolf&hash=item5d45303b9a for a number of reasons.
For simplicity youre better off buying a genuine Momo boss from JCC or DT, because itll be listed properly, itll fit, itll collapse if you need it to and itll include the thin stamped horn mounting rings that you will need to use a push button horn.
944 man
If it requires that you fit the cars existing ring then itll be no different to the Golf Mk1 boss which is cheaper. This is the problem: you don't know if theyre ignorant, disinterested or dishonest.
