steering coupling recall on 1991 911 turbo
i believe there was a recall on the 911 turbo 1991-1993 something to do with the steering coupling what exactly was the problem.
also is there any way to check what recalls there were for the 911 turbo 1991 and whether they have been carried out on my vehicle
In theory, given the VIN number, your nearest OPC should be able to tell you about any recalls that would have affected your car....and they may have access to a Porsche Cars GB database which confirms whether your car was dealt with.
Failing the OPC, try Porsche Cars GB in Reading - but they may charge you!
John
found a few recalls steering universal joint crack,crusie control problem, defective turbo control software,brake valve just want to make sure they have been done as they are dangerous if they go wrong
porsche cars reading are a waste of time and the opc say 1991 911 turbo wasnt called in for these recalls but all the data i have found has said they were where do i go from here the club referred me to the local dealer so it seems no one can help
